wing fuel drain valve leak
  • Bruce Bennett
10 Apr 2017 14:36 #1 by Bruce Bennett
Replied by Bruce Bennett on topic wing fuel drain valve leak
The leak was from the banjo fitting washers.
Thanks for the info, though.
  • Steve McNew
10 Apr 2017 14:04 #2 by Steve McNew
Replied by Steve McNew on topic wing fuel drain valve leak
Is this leaking from the valve that you use to sump the tank, when checking fuel quality for a preflight? I'm not sure about a "banjo fitting". If it IS the valve under the tank, on/under the wing, it may just be the o-ring in the valve, with a nick or a bit of something stuck in it. Not a hard fix, esp. if you have three hands!
  • Bruce Bennett
04 Apr 2017 17:24 #3 by Bruce Bennett
Thanks!
-Bruce.
04 Apr 2017 13:51 #4 by Kevin Gassert
Replied by Kevin Gassert on topic wing fuel drain valve leak
Call Skyport.
Kevin
  • Bruce Bennett
04 Apr 2017 13:49 #5 by Bruce Bennett
My A&P doesn't doubt that you are correct. He would just feel
more comfortable having documentation showing the assy.
-Bruce.
04 Apr 2017 11:53 #6 by Kevin Gassert
There are soft aluminum washers on both sides of the banjo. They are not copper crush washers.
Kevin
