- Elevator cable tension
11 Jun 2017 08:51 #1
Replied by Larry Snyder on topic Elevator cable tension
If you're thinking it's too high in the manual, it's not.
- John Phillips
11 May 2017 23:50 #2
by John Phillips
Replied by John Phillips on topic Elevator cable tension
Further to this discussion be aware that there is a revised Memorandum 38 dated 1-6-06 wherein
reference to lbs. per square inch has been deleted and the cable tension is expressed correctly in 'pounds'.
Also worth mentioning is that when doing the tensioning that the elevator should be set at neutral by whatever clever method you devise. (a light cord from the elevator trailing edge to the tip of the fin is one way).
The elevator should be set so that its weight is nullified otherwise that weight will be added to the tension and so introduce an error leading to possible over-tension.
John P.
John P.
- Kevin Gassert
10 May 2017 15:53 #3
by Kevin Gassert
Replied by Kevin Gassert on topic Elevator cable tension
Yes that is probably so. Most of us do this so infrequently that we don't really think about it so much. We get a tension meter and the dial reads pounds and I never stopped to think if it was inch pound, foot pounds or just pounds.
Kevin
Kevin
- Jack Arthur
09 May 2017 08:48 #4
by Jack Arthur
Replied by Jack Arthur on topic Elevator cable tension
i know it is hard to find a mechanic who has a cable tentioner that goes that high
- Kevin Gassert
08 May 2017 19:10 #5
by Kevin Gassert
160 to 190 pounds per inch per service memo 35 and 35A.
Kevin
Kevin
- Jack Arthur
08 May 2017 11:54 #6
by Jack Arthur
If I am remembering correctly the tension on the elevator cable is between 160 to 190 ftlbs.
