SK-21 rudder kit
29 Nov 2025 17:30 #1 by Mac McCormick
Replied by Mac McCormick on topic SK-21 rudder kit
Thanks Matt. I did finally find some good photos and it looks like the SK-21 kit adds cable extensions. Take those off, re-attach the connectors to the original cables and to the horn and boom, done.
27 Nov 2025 11:41 #2 by Matt Gunsch
Replied by Matt Gunsch on topic SK-21 rudder kit
remove the kit, reconnect the rudder cables and rig, and you are done,
27 Nov 2025 10:17 #3 by Mac McCormick
Speaking of this, does anyone have original (non-rudder) rigging diagrams? I bought "Tweety" and it has the kit in it, I am looking to remove it and restore back to its original config.
16 Oct 2022 12:56 #4 by John Phillips
Replied by John Phillips on topic SK-21 rudder kit
Rudder kit means lugging around 7 lbs.extra forever.! Compromises the foot brake.
Takes away foot room. Rudder control via the feet is not required to fly an Ercoupe. JUST DON"T DO IT. I would venture to say there are more Ercoupe's out there that are original than those with rudder pedals.
The modification falls in the same classification as a nose gear extension snubber.
Totally unnecessary.
Fred Wieck knew what he was doing. Respect his creation.
Have you read The Ercoupe by Stanley G. Thomas. Buy, beg, borrow or steal a copy. Required reading for every Ercoupe owner.
21 Sep 2022 11:37 #5 by Paul Ray
Replied by Paul Ray on topic SK-21 rudder kit
Did you get your rudders re-installed? I am just now starting the same project- reinstalling rudder pedals. My first "attempt" was a FAIL. The top of the angled plywood (that has the rudder pedals) is maybe 2"-3" from the firewall. I suspect the problem is the brake arm lever on the main floorboard - wrong position - too far rearward. Any thoughts? Thanks...
24 Jan 2022 17:18 #6 by Warren Hampton
Replied by Warren Hampton on topic SK-21 rudder kit
Also, Vern may have what you are looking for. 803-360-2061
