- Vertical card compass installation
- Kevin Gassert
15 Jan 2021 08:28 #1
by Kevin Gassert
Replied by Kevin Gassert on topic Vertical card compass installation
I am not sure how the one that they call out for the Ercoupe mounts. It looks like it takes vertical screws and nuts. That would be ok for a bubble windshield but not for a flat one. I usually use one of the center window mounts that they advertise with the horizontal screws and nuts. Also realize there are two different windshield braces in Ercoupe. Some are solid aluminum and some are hollow steel square tubing. I would not mount in either case with pulled rivets.
11 Jan 2021 18:37 #2
Replied by Larry Snyder on topic Vertical card compass installation
I tried putting one of those in my panel but something interfered badly. So mine is mounted on top of the glare shield right in front of the brace.
- Morris Pearson
11 Jan 2021 18:23 #3
by Morris Pearson
Vertical card compass installation was created by Morris Pearson
Considering a vertical card compass. Had one in my RV and liked it. Aircraft spruce has a Ercoupe custom mount for the compass that mounts to the windshield stringer. Looks like I may have to install the hanger to the stringer wilth aluminum pulled rivets. Anyone else been down this road and have thoughts to share?
