- Which Tow Bar Is This?
15 Oct 2021 21:51 #1
Replied by Warren Hampton on topic Which Tow Bar Is This?
Brady There are 3 types of tow bars. Stock Ercoupe ,The other are for double support fork nose gears . 1) is a Piper tri-pacer used on Coupes with some Mods to make it work . It has a sharper turn down to the axel with a square block on top.. The 2nd one was made for Coupes it is most rounded and one piece casting See net pictures of Coupes You will see them all .
- Brady Buttterfield
26 Aug 2021 22:00 - 27 Aug 2021 08:48 #2
by Brady Buttterfield
Which Tow Bar Is This? was created by Brady Buttterfield
My 415C has the heavy duty nose gear such as this one:
HD Nose Gear Pictured with Tow Bar
Does anyone know which tow bar this is? The "Ercoupe" tow bar I ordered from Aircraft Spruce does not fit my plane. Thanks, again!
(sorry for all the "two bar", dang auto correct)
Last edit: 27 Aug 2021 08:48 by Brady Buttterfield.
