Best Headset for Ercoupe
05 Oct 2017 17:18 - 05 Oct 2017 19:41 #1 by Gordie Meade
Replied by Gordie Meade on topic Best Headset for Ercoupe
I bit the bullet and bought a set of Lightspeed PFX. The cords are very flexible and Kevlar strong. I also bought a set of ear pads for my older Zulu 1s. I actually like the 1s better. If you watch on eBay, you can get a pretty good deal on used ones. I actually like them better than the Bose A20s I tried.
Last edit: 05 Oct 2017 19:41 by Gordie Meade.
  • Don Etchison
21 Sep 2017 11:49 #2 by Don Etchison
Replied by Don Etchison on topic Best Headset for Ercoupe
Larry. Thanks for the info. I inherited a Dave Clark 0912 model head set with my plane. It did not have active noise cancelling. My CFI suggest the 6001anr by Active Headsets Inc. as good quality and good value. It has improved my hearing in the plane substantially. I've very happy with the set for less than $400.
  • Larry Pearson
21 Sep 2017 07:49 #3 by Larry Pearson
Replied by Larry Pearson on topic Best Headset for Ercoupe
I upgraded from a Clark 13.4 to a LIghtspeed Zulu 3 this summer and am happy that I did. I have slight hearing loss and it made a big difference.
28 Aug 2017 22:43 #4 by John Phillips
Replied by John Phillips on topic Best Headset for Ercoupe
Nuts ! I meant A20 Bose.
John P.
28 Aug 2017 22:40 #5 by John Phillips
I bought the first generation Bose to use in a 206 commercial helicopter.
Smartest thing I ever did to enhance radio communications and to save my
hearing. The succeeding generations have only got better . I now have 2 of A10 model for the 'coupe.
The A10 has auto off. The bluetooth is GREAT to couple to your cellphone for emergency or routine calling.
The Bose automatically adds 'soundproofing' to the 'coupe with no added cost !
Go first class. You won't regret it.
John Phillips
415C s/n 4375
  • Don Etchison
25 Aug 2017 08:19 #6 by Don Etchison
Scott. Thank you. It's certainly acknowledged that Bose is the top of the line and the most expensive. I got a tip about DRE with ANR noise cancelling and this set is less than half the cost of Bose. The initial test with them was great. The ANR made a huge difference.
