× This is the optional category header for the Suggestion Box.
Things you should have
  • Edward Woerle
13 Oct 2024 10:07 #1 by Edward Woerle
Replied by Edward Woerle on topic Things you should have
YOU said 718 AND 787! Hey, we agree on something.
12 Oct 2024 22:37 #2 by Warren Hampton
Replied by Warren Hampton on topic Things you should have
I have both. Just because I want to.
12 Oct 2024 22:04 - 12 Oct 2024 22:35 #3 by Warren Hampton
Who in the HELL said anything about using another Models data? 787 Covers D thur M10sRead the Dame TCDS We are not talking about putting a DC3s to a 415 airframe here...718 Cover both C AND CD... I guess I needed to say your TC!  or I am too anal!
Last edit: 12 Oct 2024 22:35 by Warren Hampton. Reason: Add more
  • Edward Woerle
12 Oct 2024 21:00 #4 by Edward Woerle
Only problem is if you use info from aircraft you don't have you render your aircraft unairworthy. Part of definition of 'airworthy' is that Your airplane meets the specs for YOUR airplane. Not one similar, but one manufactured to YOUR TCDS. Other TCDS doesn't count no matter how similar it is. If you own an ALON you MUST use the Alon TCDS. If you own an Ercoupe you MUST use the Ercoupe TCDS. Otherwise an unairworthy airplane!
12 Oct 2024 16:16 #5 by Warren Hampton
Easy to answer. The data within it! From adjustments of controls to storage lbs that you can load. If you put a 9 cu ft in you are still limited to the given lbs.
  • Edward Woerle
11 Oct 2024 21:28 #6 by Edward Woerle
Why would you need the TCDS for an aircraft you don't have?
