charging the battery
17 Jun 2019 23:19 #1 by Matt Gunsch
Replied by Matt Gunsch on topic charging the battery
read up on what type of charger to use, if you use the wrong type, you can toast the battery
  • Henry Pasquet
17 Jun 2019 08:48 #2 by Henry Pasquet
Replied by Henry Pasquet on topic charging the battery
Aircraft batteries are often damaged by a complete discharge. Check it closely after you charge it. I had to replace mine after a ground check of the radio and not turning off the master.
16 Jun 2019 15:09 #3 by Larry Snyder
Replied by Larry Snyder on topic charging the battery
Just charge it like any battery.
Suggestion for the future: always leave your beacon switch ON. That way, if you leave your master on you should see the beacon flashing and can turn the master off. I always leave my beacon and nav light switches on.
  • Dennis Tar
16 Jun 2019 14:20 #4 by Dennis Tar
charging the battery was created by Dennis Tar
Any advice to a brand new 415C owner who left the master on and now needs to charge the battery
