- engine oil do you recommend for the the C.90 16F
- 8419
28 Apr 2016 13:23 #1
by 8419
Replied by 8419 on topic engine oil do you recommend for the the C.90 16F
I've had the best luck with Exxon Elite 20W50, with a can of Avblend added with each oil change. Nothing sticks. The one time I went back to Phillips X/C with no additive my lifter started sticking. Went back and it's fine. Mine's a C85, but I don't think there is any appreciable difference here. Remember, these small Continentals are prone to sticking valves and lifters.
Larry
N99340
Larry
N99340
- Grover Anderson
19 Apr 2016 08:14 #2
by Grover Anderson
Replied by Grover Anderson on topic engine oil do you recommend for the the C.90 16F
Which oil do you recommend for the c. 90 16F
Grover Anderson
Grover Anderson
- Grover Anderson
26 Mar 2016 13:45 #3
by Grover Anderson
Which engine oil do you recommend for the C.90 16F
Grover Anderson
Grover Anderson
- Grover Anderson
12 Mar 2016 17:22 #4
by Grover Anderson
engine oil do you recommend for the the C.90 16F was created by Grover Anderson
Which engine oil do you recommend for the C 90-16 F in an Alon Aircoupe.
Also can the camshaft be overhauled?
Thanks,
Grover Anderson
Thanks,
Grover Anderson
