- 9 cubic foot baggage compartment
- Michael ODonnell
16 Oct 2024 12:24 #1
by Michael ODonnell
Replied by Michael ODonnell on topic 9 cubic foot baggage compartment
Thank you for the response. It is most informative. It seems as though it is to require more time than I thought, however, it will be a nice winter project. Thanks again for going into so much detail. It is very much appreciated.
Mike
Mike
14 Oct 2024 18:53 - 14 Mar 2026 01:33 #2
Replied by Brooks McNew on topic 9 cubic foot baggage compartment
It's not an especially difficult job, but you will need to devote some time to it. I spent about 21 hours on the project. split over 5 days, so I wasn't really in a big rush.
If your window welts are in bad shape this is the PERFECT time to replace them since you now have full access to remove the inner skins and access the entire side window rail system. Also, if your side window skins or seat pan have cracks this is a great time to patch them. You can get a piece of aluminum and cherry pop rivets to do this.
The baggage compartment itself went in without a hitch. The only extra steps I had to take were to cut out a little extra material to get clearance around my 3-point seatbelt STC, but this was quite obvious what was needed and also easily accomplished. My master switch relocated with no change to wiring but one of my strobe light wires needed to be lengthened to reach the new location. That's what I get for cleaning up all the "excess wire length" last year!
- I purchased a used baggage compartment from Vernon that was complete except for the wooden floorboards. The used parts (and the STC does specifically approve the use of "salvaged" parts) were $450 and I purchased a very nice 4'x8' sheet of 1/4" (actually 6mm) Okoume plywood for about $120. Turns out I would have been fine with a half sheet though.
- I stripped, primed, and painted all of the metal components using normal hardware store supplies. Maybe $45 all told.
- Vernon sent me all of the nuts, bolts, and screws from the previous installation but I elected to use all new hardware. That all cost about $60 with shipping and there is a parts list here .
- Besides normal hand tools and a cordless drill, you will need a 6x32 thread tap. I already had a full set , but for this job you're only threading four shallow aluminum locations so a cheap tap like this will do nicely. You'll also need a set of numbered drill bits. If you're not too precious about your tools there's a decent but cheap set available here . So unless you elect to buy more expensive stuff, less than $50 worth of tools.
Last edit: 14 Mar 2026 01:33 by Brooks McNew.
- Michael ODonnell
14 Oct 2024 08:18 #3
by Michael ODonnell
Thanks for the info. I am looking to replace the worn and ripped canvas bag How involved is the change over to the 9 cu ft space? Also, costs?
Mike.
Mike.
11 Oct 2024 18:05 #4
Warren is correct. In fact, the STC paperwork anticipates this. One of the last steps is to apply a "Maximum Baggage Capacity" placard - in that step you're instructed exactly how to compose the placard text depending on your Ercoupe model.
11 Oct 2024 17:59 - 11 Oct 2024 18:07 #5
Replied by Warren Hampton on topic 9 cubic foot baggage compartment
If you have a copy of the type Certif you can see for your model how much you can put back, there. TC 718 or TC 787. to know your Coupe C to M10 have a copy at hand !!! (BOTH ARE HERE UNDER ( DOCUMENTS )
Last edit: 11 Oct 2024 18:07 by Warren Hampton. Reason: Add more
10 Oct 2024 18:23 - 10 Oct 2024 18:26 #6
As Larry said, the max baggage capacity is 65 pounds.
I have a Weight & Balance spreadsheet, and I can't make it go out of CG range with any combination of fuel/occupants/baggage unless I start doing things like, two heavy pilots, full baggage, empty wing tanks, and half empty fuselage tank. Even then, it's an inch out beyond aft CG.
At that point, you're dealing with the assumption that baggage weight is evenly distributed throughout the baggage area. If you stack the heavy items towards the front you're back in CG.
For the future, I'd like to get approval for a EarthX battery instead of replacing the heavy Concorde lead-acid battery. That would remove 19 pounds from just below the forward edge of the baggage area, which would shift the empty CG just enough to make it more or less impossible to misload the aircraft.
Last edit: 10 Oct 2024 18:26 by Brooks McNew.
Time to create page: 0.082 seconds
