Oil leak under panel?
  • 8419
04 Sep 2016 15:57 #1 by 8419
Replied by 8419 on topic Oil leak under panel?
There is a small metal tube that runs from your engine to the oil pressure gauge that is filled with oil at engine pressure. Check the connection of the tube to the back of the gauge for a leak, otherwise there must be a hole in the tube somewhere.
  • 10132
04 Sep 2016 15:40 #2 by 10132
Oil leak under panel? was created by 10132
Flew my coupe the second time since replacing the engine and wings. This time I flew for twenty minutes. Flew great! When I landed, shut her down, I felt something hot on my left leg. Looked down & from my knee down, was oil soaked! Slid her in the hanger and proceeded to look for the leak. Looks like the temperature gauge? Not understanding this set up. How can the oil line just go into the gauge without putting pressure there? Should it be like a " round robin"? Should it build pressure? Thanks in advance for any insight on this subject.
